Richard Moakes
- May 19, 2002
- Location
- Newton Abbot, Devon, UK
- CL500; ML500
Yes, cover everything in Dynax UB before its rotten, and it will stay like that. Re-apply every 2 yearsWould a coat of a 'water and salt repellant' on these pipes reduce the efficiency of the cooling down I wonder.
A prestige car manufacturer took this to the extreme and found that stainless wheel bolts kept becoming loose.I plan to ....... replacing every rusty screw/fastener with marine grade stainless items
Oh yes, stainless can be quite soft, but the screws for every clip holding the pipes snapped due to corrosion when I was dismantling it, so will replace all of those with stainless.A prestige car manufacturer took this to the extreme and found that stainless wheel bolts kept becoming loose.
no the are feed pipes to the cooler, not the actual heat exchangerWould a coat of a 'water and salt repellant' on these pipes reduce the efficiency of the cooling down I wonder.
Hi,A word of caution to all W221 / C216 owners, be sure to check the metal fluid lines running to the additional transmission oil cooler mounted in front of the AC condenser. Mine rusted out and started leaking, the replacement of which has turned into a cascade of parts replacement.
Hi Robin,Hi,
I'm new here and just registered to ask you a question:
Did you replace the cooler lines yourself? Can it be done without removing the radiator and disconnecting the A/C lines?
Cheers,
Robin.
